Onkyo sr805 display gone any ideas?
gtione
My trusty Onkyo seems to have lost its display. Amp still working just no front display. I have checked the dimmer etc and all fine
Any oft else experienced this on any Onkyo amp and what the fix was?
Thx in advance.
stevelup
You haven't got the 'pure audio' button pressed have you? Just a thought as that blanks the display.
gtione
No mate never used that and the blue light around that button be on, right?
stevelup
Yep - if the blue light is on, the display will be off. It was just a suggestion - stranger things have happened!
gtione
To true, thx
steelman1991
Had a similar problem. On holiday at the moment will post link to the solution when i get home tomorrow. There is a thread on avsforums.
Small resistor requires replacement.
gtione
So the agents have quoted £96 to fix. Is this reasonable or are there any cheaper options out there? Not handy with electrics so the DIY fix is a no no for me.
steelman1991
Repair cost me approx 0.69c for the resistor - bought in Radio Shack last year while on holiday in the States.
Soldering skills are required - Brother-in-Law completed the task in around 5 minutes. Get the parts and someone with soldering experience, buy them a couple of beers and save the £96.00 (what a rip-off), hope I'm not breaking any rules linking to another site - "The" Onkyo TX-SR805 Thread - post #17388 onwards.
Good luck.
007L2Kill
Like steelman1991 said that’s a rip off:eek:, you only need two resistors which cost no more than a fiver and of course soldering skills. Mine onkyo 875 display died about five months ago and fixed it mine self, took less than an hour to do and the longest bit was trying to get the dam cable off.
Do you know someone who can solder the parts for you?
gtione
Hmm. Unfortunately not although I am beginning to wish I did. I suppose they have me over a barrel on this one unless I can find somebody else willing to help out.
gtione
Oh and this price is if I drop off and collect other wise add another £30 for carriage costs. So that would total £126 all in.
The worst thing is I have send the same unit sell in the classifieds for £150-£170.
007L2Kill
Well that is just stupid I thought the price included shipping so now it’s a total rip off!
Well if you know how to remove the board I am willing to do the soldering for you as long you cover me for the parts and return post as you live in the UK so that should be no problem.
Mike.:)
steelman1991
Why not do as suggested in the AVS thread, take it to a local electrical store and ask them to solder the part - taking the original article with you as reference. Should certainly save you the delivery charge and I would suggest a bundle of the repair cost.
Seriously save yourself some dough and don't encourage these people - at least Dick Turpin had the decency to wear a mask. Oh and time to extend your circle of friends :smashin:
gtione
Mike.:)
Mile, wow that is a kind offer. I live in Surrey, is that a ways from you? Can the amp still be used with that board out of play?
I would gladly cover all the expenses. Is the board easy to remove? Never opened the amp before?
Thx a million for your support with this matter!
goujam
Just one more suggestion you could get down to maplin and buy one of there soldering kits ! Ask a member of staff for help choosing one and learn to solder it will take you a day to get to a decent standard then you can repair it your self and you get a skill that always comes in useful !
The amount of repairs I do for friends and people at work I could start my own repair shop !
gtione
Thx for the suggestion. I tinker and fix many many things including computers, radio controlled car & planes an things around the house.
Never really soldered before and the thought of messing up the board let alone not knowing what I am doing puts me off. And if I do make a balls up of then I gotta find £1k to replace it.
Thankfully there always very kind people on here willing to give selfishly of their time to help other people with similar interests.
gtione
Well this problem has now been solved for the pricely sum of £5 plus some postage due to a very helpful forum member to whom I am very very greatful.
The agents wanted £96 + £30 postage to replace parts the cost £3.50.
Once again a member of this forum has come to the rescue and served this community with pride.
We should be very proud..:clap::clap::clap:
dougan
My Onkyo 607 display disappeared last week also. Having seeing this thread, I ordered 20 x 10ohm -1W resistors from ebay for £1.99 delivered, which arrived today.
Lets hope it cures mine also!
gtione
Good luck mate let us know the outcome.
dougan
Will do!
Doing it today, just not looking forward to diconnecting it and removing it form the tv unit, cables, cables............
gtione
dougan said:
Will do!
I feel you, been there done that but hey a good good chance to get rid of all the dust etc. good luck mate!!!
dougan
Just stripped my 607 down, and there is no display board as shown in the 805, bugger!
I just presumed it would have been the same board, I suppose the 607 is less deep so uses a different layout.
Annoying thing is, it is probably only a blown resistor, but it looks like it may be burried deeper inside the unit.
Have been quoted £130 for the repair, as the amp is nearly 3 years old, am I better off buying a new one?
gtione
I was faced with the same issue. My repair bill would have been nearly £130 and second hand ones have sold on here for around £150.
Search around on the Internet for the offending part and then attempt the repair first.
PSM1
Although a secondhand one of the same age may have the same issue lurking inside so could fail at any time after purchasing it. Getting your fixed should mean getting the problem sorted so it lasts longer.
scottthehat
have you checked all the internal fuses a remember seeing somewhere that this can cause this problem.
Latest News
iFi Audio launches NEO Stream music streamer with DAC
  • By Ian Collen
  • Published
Musical Fidelity launches M6x 250.7 multi-channel power amplifier
  • By Ian Collen
  • Published
Is Google set to rival Dolby Vision and Atmos?
  • By Ian Collen
  • Published
'Tizen TV by Samsung' brands coming to UK?
  • By Ian Collen
  • Published
Denon announces five new 8K AV receivers
  • By Ian Collen
  • Published
