I am buying a receiver and speakers for my mother and need help with the decision. I am looking at either an Onkyo Onkyo HTS5400 that come with speaker or Sony STR-DH810 and will be adding the same speakers. The price end up about the same. You can get more information on the Onkyo set up on Vanns web site and the Sony on Walmarts site. I am including some details below and help or suggestions are appreciated. From the research I have done the Onkyo receiver is 3D and the Sony does not come 3D but with a firmware upgrade will work with 3D. 3D is not mandatory. Thank you.
Sony STR-DH810
DSP Presets: Hall, Stadium, Jazz, Concert, Virtual Multi Dimension, Cinema Studio Ex. A, Cinema Studio Ex. B, Cinema Studio Ex. C, Sports Surround System Class: 7.1 channel Response Bandwidth: 10 - 70000 Hz Amplifier Output Details: 110 Watt - 8 Ohm - at 1 kHz - THD 1.0% - 7 channel(s) ( surround ) ¦ 100 Watt - 8 Ohm - 20 - 20000 Hz - THD 0.09% - 2 channel(s) ( main ) Built-in Clock: Sleep timer Timer: Sleep Bass Control: Yes Treble Control: Yes Display Dimmer: Yes Additional Features: A/B/A+B speaker switch, Bi-Amplifying, Midnight Mode, auto sound calibration, dual-zone capability, compressed music enhancer, S-AIR technology, Audio Return Channel (ARC), BRAVIA Sync Sound Output Mode: Surround Sound Built-in Decoders: Dolby Pro Logic, Dolby Pro Logic II, DTS Neo:6, DTS-ES Matrix 6.1, DTS-ES Discrete 6.1, DTS 96/24, Dolby Digital, DTS decoder, Dolby Pro Logic IIx, Dolby Pro Logic IIz, Dolby Digital Plus, Dolby TrueHD, DTS-HD Master Audio, DTS-HD High Resolution, Dolby Digital EX Surround Sound Effects: Digital Cinema Sound EX Digital Sound Processor (DSP): Yes Input Impedance: 50 kOhm Input Sensitivity: 500 mV Built-in Display: Fluorescent Audio D/A Converter: 24bit / 96kHz Signal-To-Noise Ratio: 96 dB
Onkyo
Sony STR-DH810
Onkyo
- 130W/channel x 7 channels + 120W subwoofer output power= 1030W total system power
- Decodes Dolby TrueHD, PLIIz, DD Plus; DTS HD-Master Audio, HD-High Resolution Audio
- Front speakers: 5" OMF cone woofer, 1" balanced-dome tweeter (2-way, bass reflex) / Surrounds: 3.25" cone woofer
- Center speaker: two 3.25" cone woofers, 1" balanced-dome tweeter (2-way, bass reflex)
- Subwoofer: 10" bass reflex; wood cabinet, powered
- 4 HDMI v1.4 inputs, 1 output (with Audio Return Channel)
- 4 digital audio inputs (2 optical, 2 coax), 6 analog audio inputs, 1 output
- 2 HD-capable component video inputs, 1 output / 5 composite inputs, 2 outputs / front-panel USB port, subwoofer pre-out, speaker A/B terminals
- Includes remote control
- Discrete amp construction / 4 DSP gaming modes (rock, sports, action, role playing)
- Music Optimizer / Audyssey 2EQ microphone calibration / Audyssey Dynamic Volume / Audyssey Dynamic EQ
- Direct digital connection for iPod/iPhone via front-panel USB port
- Optimum gain volume control circuitry, theater-dimensional virtual surround function, CinemaFILTER, A-form listening mode memory
- Banana plug-compatible speaker posts, color-coded speaker terminals
- AM/FM antenna inputs; 40-station memory (FM: 87.5 MHz-107.9 MHz / AM: 530 kHz-1,710 kHz)
- TI Burr-Brown 192kHz/24-bit DACs for all channels
- Advanced 32-bit processing DSP chip
- EX.Bass, double bass function
- Tone control for front L/R channels
- 80W/channel at 8 ohms, 20Hz - 20kHz, 0.7% THD, 2 channels driven, FTC
- Speaker impedance: 6 ohms - 16 ohms
- Signal-to-noise ratio: 100dB
- Frequency response: 20Hz-50kHz/ +1dB, -3dB (DSP bypass) / component video frequency response: 5Hz - 100MHz/0dB, -3dB
- Approximate dimensions:
- Surround/Surround Back speaker (each): 4.50" W x 9.06" H x 3.75" D; 2.2 lbs
- Center speaker: 16.56" W x 4.50" H x 4.75" D; 5.1 lbs
- Front speaker (each): 6.13" W x 14.81" H x 6.69" D; 5.7 lbs
- Subwoofer: 12.50" W x 18.25" H x 15.69" D; 23.8 lbs
- Receiver: 17.13" W x 5.88" H x 12.94" D; 18.1 lbs
