onkyo/ ps3 volume
Discussion in 'AV Receivers & Amplifiers' started by maxwan, Sep 14, 2007.
Tags:
  1. maxwan
    maxwan
    Mar 19, 2003
    591
    southyorks
    +12
    hope you new owners of the onkyo 875 can help
    i have downloaded a few demo games on the ps3 and the problem is when i played a dvd then stopped play and moved the cursor on the playstation menu on to virtual tennis demo the volume on it nearly took my head off . can the volume be adjusted on the amp so it is the same as when you play a dvd
    hope you can understand what i mean
    regards
  2. t1m103
    t1m103
    Jun 29, 2005
    1,856
    essex
    +191
    lol,your right the volume on the demo thumbnails is way louder,not got an onkyo but a denon i recon it must be the same for everyone.one thing i have noticed tho is sometimes when i turn the ps3 on the sound will come throu my tv via the hdmi then other times it wont,it will only come via my amp and optical,which it is set to do.
  3. Curly99
    Curly99
    Dec 29, 2006
    9,426
    +2,255
    should be able to do this from the menu..can't remember exactly which part but it's the intellivolume bit
    Curly
    edit didn't read it was the 875...probably the same on that as the 605
