Onkyo ht-r390 audio switching
Discussion in 'AV Receivers & Amplifiers' started by Bassquake, Jan 9, 2012.
Tags:
  1. Bassquake
    Bassquake
    Dec 8, 2009
    12
    I have the Onkyo ht-r390, I route the hdmi out to the tv, a ps3 is plugged with hdmi on the bd/DVD channel and an xbox (original) is plugged into the coax, the xbox is using component to the tv (not thru amp). The problem is that no audio comes thru on the coax UNLESS I turn the ps3 on, then turn it off. This seems to force the amp to switch over to coax. As this is very annoying, anyone know how to stop this?
    Many thanks in advance.
  2. Bassquake
    Bassquake
    Dec 8, 2009
    12
    Shame no help here, figured out a way to switch audio manually without having to turn on and off the PS3.
    Goto on the Onkyo: Setup > Audio Selector and change HDMI to CoAxial. Change back for PS3.
    Not very convenient but was the only way I could get it to work. Seems the amp locks onto HDMI if a cable is plugged in regardless if a signal is coming through or not.
