Onkyo DV-SP406, Samsung DVD-HD870, Toshiba XD-E500
nevermore80
Trying do decide between these three players....
The toshiba - one things ive heard on this player is that it will only display 4:3 stretched to 16:9 - is there any truth in this?
Is there a HUGE difference in picture quality between these three models? Or should i just see which one i can find cheapest?
Or, is there another cheap upscaling DVD player out there that i may have over-looked?
Any advice always appriciated!
abdus
I have a Toshiba SD580 but returning it and getting SP406. While the SD580 was excellent for the price, it is almost impossible to make it multi region. (i bought it from amazon)
You can either get one from Superfi which is already multi region, but at £5-6 more expensive the Onkyo seems to be the better option.
I haven't tried the Toshiba XDE500 though. but I didn't like the looks..LOL. Not sure why
Both got 5 from whathifi awards 2008 with the Onkyo being the best budget player under £100
The Sony mentioned above has the best design of them all imo.
colly
i am after the 580 is it only the multi region problem why you are not keeping it
see i brought the tosh 42 xv555 and after a good player for it
abdus
yeah, but you can get it here MR. I didn't check before buying. and I thought it would be easy to hack but unfortunately it's not
TOSHIBA SD580E DVD PLAYER (MULTI-REGION) - available from Superfi UK Visit http://www.superfi.co.uk/index.cfm/page/moreinfo.cfm/product_id/4734 for details
I'm yet to decide between the Onkyo 406 or the Sony DVPNS708/78. The 406 isn't the best looking...lol
Podcast: Anthem AVM 70 Review, EQing Your Home Cinema Sound System and More...
