Onkyo cs-515 system
Discussion in 'Hi-Fi Stereo Systems & Separates' started by daznufc, Sep 12, 2007.
  1. daznufc
    daznufc
    Jan 31, 2007
    76
    Ive read this is a excellent cd micro system which would likely be suited to my small bedroom, can anyone suggest what to do speaker-wise or if infact this system isnt as good as advertised?:)
  2. andyhayward
    andyhayward
    Nov 7, 2006
    50
    I have this system and have paired it with Q Acoustic 1020's and it sounds amazing. I think you would have to spend quite a bit more to better the sound from the Onkyo. I can't recomend it enough.
  3. matt78
    matt78
    Sep 16, 2007
    102
    +14
    I'm running a CS-515 with Monitor Audio Bronze B2 speakers on spiked Atacama stands and it sounds superb. Soundstaging is awesome for a unit of this price and it copes with all types of music incredibly well. Don't be tempted by the packaged speakers though as they won't get anything like the best sound out of the electronics. The better the speakers, the better the unit sounds (the electronics are THAT good). I can only recommend the Onkyo/MA pairing. Avoid using MS902s (Mordaunt-Short) as they don't work well with this unit.
