Onkyo CR-515DAB v Denon D-M33DAB Ipod docks
chairboy
hi I'm thinking of getting either Onkyo CR-515DAB or Denon DM-35DAB for the bedroom.
I have a Denon ASD1R dock.
Is there any reason why it would not work with the Onkyo?
The blurb states that the dock is designed to work with the DM-35DAB but i can't figure out what extra functionality is gained over that provided by a simple by a 3.5 jack connection (ie no remote control/display support).
WibXL
I've got the Onkyo machine with the Onkyo dock and if the Denons work in the same way then by matching them up you'll be able to control the Denon dock with the remote for the Denon machine. If however you matched up the Denon dock with the Onkyo machine then it's likely that the Onkyos remote wouldn't work with it and that you would either have to use the remote that came with the Denon dock if it came with one or use the click wheel.
Podcast: Best Home Cinema Sources and B&W 805 D4 Speaker Review and more...
