Onkyo Assignable Inputs
Discussion in 'AV Receivers & Amplifiers' started by PuzZah, Jan 30, 2009.
Tags:
  1. PuzZah
    PuzZah
    Feb 16, 2005
    43
    Figured this forum would be the most likely place to find someone who knows the answer to my question. If it's not, my apologies, and please move my thread to the appropriate forum.
    Many Onkyo (and other brands) amplifiers have assignable inputs on the back and what I'd like to know is whether or not I would be able to assign multiple inputs to one button on the front. For example can I assign a component input taken from a Nintendo Wii to the button labelled Game/TV and also assign a hdmi input taken from an Xbox 360 to the same Game/tv button?
    The reason for doing this is simply because I'd like to be able to press the button which has the correct printed label on it, turn on whichever console and it select the right input.
    As of yet, I haven't decided on a particular model so it's a generic question on a budget of approximately £300-350.
    Thanks for your time and any suggestions/advice you can give me.
    Regards,
    Ben
  2. Uridium
    Uridium
    Jan 29, 2005
    14,434
    North West Leicestershire
    +1,855
    I have PS3 and Wii both assigned to Game/TV button on my Onkyo 606. PS3 connected via HDMI and Wii connected via component.
  3. PuzZah
    PuzZah
    Feb 16, 2005
    43
    Thanks for the reply. That's really useful to know. Do you know if there is a maximum number of input ports I could assign to a button?
    Ben
  4. Uridium
    Uridium
    Jan 29, 2005
    14,434
    +1,855
    Think you can assign as many as you want. It will just display the one that is sending an active input
  5. stevelup
    stevelup
    Aug 13, 2002
    6,795
    Swindon
    +1,300
    That's not quite right.
    The only input that has priority is HDMI - if the HDMI input is not present, it falls back to whatever the assigned analogue source is.
    If you have assigned one of the inputs as HDMI and Component, then it will display either HDMI or Component - it won't fall back to composite/s-video if the component input is missing.
  6. PuzZah
    PuzZah
    Feb 16, 2005
    43
    Hi stevelup,
    Would it fall back on a composite s-video source if i were to assign said source to the button as well as a hdmi and component.
    For example, Xbox 360 on HDMI, Wii on Composite, and let's say a nintendo 64 on composite. Would the nintendo 64 ever get a look in? If it was the only active input source of the 3?
    Thanks for your help
    Ben
  7. stevelup
    stevelup
    Aug 13, 2002
    6,795
    Swindon
    +1,300
    No - it works as I described it.
    HDMI falls back to Analogue. There is no further fallback from one kind of analogue to another.
    Which analogue it falls back to depends on whether or not you assigned a component input to that source.
  8. PuzZah
    PuzZah
    Feb 16, 2005
    43
    Ok thanks that's good to know.
    With regard to the above quoted statement, is this true? What about adding multiple HDMI inputs with a component to fall back onto?
    Thanks again.
  9. stevelup
    stevelup
    Aug 13, 2002
    6,795
    Swindon
    +1,300
    Unless something has changed radically between the x05 and x06 series of amplifiers, then this is not correct. You can only assign one HDMI or Component source to each input.
  10. PuzZah
    PuzZah
    Feb 16, 2005
    43
    Thanks for your replies stevelup. I've just managed to get hold of a tx-sr606 and you're correct, one hdmi input, and 1 component input can be assigned to the button.
    Thanks again.
    Ben
