Onkyo A9010 to MacBook Pro (USB C) - Best way to connect?
W0LFIE
hi folks,
Just after advice re best way to connect my MacBook Pro to my new Onkyo A9010 mainly for Spotify playback.
My guess is USB C adaptor to RCA but noticed I also have an optical & a coax slot.
Already running a turntable through the phono input.
Also any advice re best place to pick up relevant cable much appreciated.
Many thanks in advance for any help offered :lesson:
D
Deleted member 24354
Why not look at a USB DAC like Audioquest Dragonfly RED / Cambridge Audio DAC Magic / Cyrus Soundkey they would all give you a substantial upgrade on your Macbook Pro's onboard DAC and would allow you to use on of your analogue input channels on your amp.
W0LFIE
Thanks, didn’t know about DAC
I might consider that but it’s extra £70+ I wasn’t planning on spending- plus Id still need to buy my analog cable (I need about 4-5m).
Might ask Richer Sounds to demo a Soundkey to see what difference in quality is.
I bought a USB C to 3.5mm adaptor for my Macbook only to discover it actually has a 3.5mm port. Will return it to Curry’s for my £10 back.
