dUnKle
My now 6 and bit your old Onkyo 905 has given up the ghost, or at least is on its way out
It now rarely holds any settings, meaning before can settle down and watch anything you need to check all settings to ensure speaker levels etc are correct and also 2 of the sets of speaker connections suffered a bad knock in a recent move
My budget is £500 (at the real most) and I have the choice of the following (would go and buy from Creative Audio as only up road from me)
Onkyo TX-NR616 7.2 @ £319
Yamaha RX-V671 7.1 @ £349
Yamaha RX-V673 7.2 @ £449
Yamaha RX-A1010 Aventage 7.2 (B Grade) @ £499
Now gone are my days of running the amp loud and annoying the neighbours. Since I purchased the 905 I have started to live in the real world. I no longer have my SVS cylinder sub and just use the Kef 2005 Speaker package in 5.1
The amp is mainly used for an equal mix of Blu Ray, SkyHD and Gaming (360, PS3 and WiiU)
I suppose the only upgrade I may be fortunate to go to in next few years would be a newer TV, so maybe 3D at that point but I dont think my room would allow me to have more than 2 rear speakers
Any suggestions ?
Any suggestions ?
