Onkyo 818 not displaying DD over 3.0 Sky HD?
Discussion in 'AV Receivers & Amplifiers' started by canada16, Feb 23, 2013.
Tags:
  1. canada16
    canada16
    Nov 15, 2009
    1,052
    Cardiff
    +45
    Hey.
    My amp used to change to Dolby when I was on Sky HD.
    I have went through every channel and none of them are lighting up my amp.
    I have put a optical in the Amp and Sky Box.
    I have assigned audio in the amp under Sat. for optical 1
    And the Sky Box is set up correctly.
    Any thoughts, as I have moved, and cant remember what I did last time.
    Optical lead: Check
    Input Assign: Check
    Sky HD: DD Signal check.
    But nothing is lighting up the Onkyo TX-NR818 were it scrolls across Dolby Digital.
    Thanks so much.
    I have no rear speakers at the moment, but that should not stop the amp lighting up dolby Digital... Or Should it.
