I've just purchased a second-hand 805 and the remote doesn't seem to work, have spent all evening googling etc., and can find no information about a similar issue. I've tried brand new batteries etc .
The little red light at the top of the remote is constantly flashing and none of the buttons have any effect, even the backlight button doesn't work. I've tried doing the reset as described in the manual, and selected all three remote channels on the amp.
The only difference in behaviour is after removing/replacing a battery I get a steady red, that lasts until the first button is pressed then the constant flashing starts again .
The receiver hasn't been used by the previous owner as was intended for a project that never happened so he's no idea if it worked before or not.
Any advice much appreciated
Thanks,
Chris.
Thanks,
Chris.
