ekay
Established Member
TV- Sony 498505
AMP- Onkyo 636
Speakers- Q700i
Hi guys,
Having a few issues with my new set up. Hoping that someone who has used this already will have knowledge of some fixes!
1 – I have activated the HDMI through so that I can use Sky if the amp is in standby. However something a little strange is happening. If I turn the TV on, then the Sky box….the amp turns on too (same time as pressing sky button). When turning the sky box off…the amp stays on. It only turns off, if I turn the TV off! Is there a way to stop this? I would prefer to turn the amp on from it’s own remote.
2 – I’m getting sporadic lip sync issues. Admittedly the only source at the moment that is connected is the Sky box. The TV I have is a Sony 49x85. I tried to use the audio delay on the sky settings, but it just makes it worse. Is there a way around this? It’s really bugging me!
3 – In the options there is a ‘Listening Mode Preset’ section. Everything is set to ‘last valid’…is this correct? Some of the options are ‘2ch Source, Dolby D/Dolby D Plus/True HD, Analogue PCM’….plus a few more. Should these be set to anything else?
4 – In the Firmware Update section, when trying to update the version, it says ‘unable to check for firmware update’….I’m assuming this isn’t good! The amp is connected wirelessly to my network at home….it all seems to work too, as I’ve tried the tuneIn radio app.
Apologies for the long winded post but any help will be massively appreciated.
Cheers!
AMP- Onkyo 636
Speakers- Q700i
Hi guys,
Cheers!
