Hi All
I have the following issue
I have a under TV cabinet....this is pretty low slung...and this has a draw on each side, and centre open for HE kit.
I have since altered this setup from the inside, and externally now still shows the right look
Let me clarify
Left hand side.
This is still a draw. With a draw (wood) front in place
Centre ( open )
Onkyo 609
Revo Media Centre
Right hand side
This now has inside
SKY HD+
Sling Catcher
Network Switch
But the door front is still in place...so it looks standard and as it did prior
I have tried 2 different IR senders to the SKY HD
(the original one from SKY plus) and also one from Maplins (Nikkai IR Sender)
There is apparently settings in the Onkyo to control the SKY HD via the HDMI cable? I think this kinda works....but its a bit hit and miss.
As you can see...the SKY box is hidden away...and controlling the thing is a real pain now.
I have a Harmony One Remote too... but never set it up...as I know controlling the box needs to be sorted first.
So.. Now I need to know... Is there a much better (known working) IR repeater...that I can locate under the TV...and into the right draw...or if the Harmony is able to control all the items in the draw?
I know the PS3 can be controlled via the Harmony One also... but with a PS3 addon?
Please help.. I've spent alot of money on this kit...and its peeing me off..that i cannot control the kit as i should be able to.
See pics below
Let me clarify
Left hand side.
Centre ( open )
Onkyo 609
Revo Media Centre
Right hand side
This now has inside
SKY HD+
Sling Catcher
Network Switch
See pics below
