Onkyo 607 - No Display!
dougan
Switched on my Onkyo 607 last night, and I have no main display, only the red led standby, no main display at all. Everything seems to be working ok, volume, switching etc, but with no display it is pretty much useless!
Any ideas on what it might be? Has the display blown or could it be a simple setting I have missed? It is 32 months old, so out of warranty.
PSM1
I know on my arcam I can turn the display dimmer and off with a press of a button. Are you sure you have not (or someone else in the house) accidentally pressed a similar button on your Onkyo. Have a look in your manual to see if it tells you how to do it or if it can be done. Otherwise it sounds like the screen has failed.
goujam
Im sure its a common problem on onkyo receivers for the display to break ! I'm sure its just a matter of replacing 1 or 2 resistors. Try searching the forum I'm sure.someone had this fault not to long ago
dougan
Many thanks for the comments.
Have tried the pure audio mode, and a blue led lights up on the panel, still no display though. I now have the Zone 2 led lit, and cannot seem to switch it off, if I press the button it just flashes and then stays lit, strange!
Will take a look at the thread regarding the resistors, thanks!
goujam
You could try a factory reset of it ! It's normally turning the unit off holding some buttons then turning it back on !
Similar threads
