Onkyo 605 - how to get info on tv?
Discussion in 'AV Receivers & Amplifiers' started by leo79, Jan 29, 2009.
Tags:
  1. leo79
    leo79
    Mar 9, 2008
    1,218
    116
    +582
    Hi, I've had my 605 for some time now but recently i have put everything away in a cupoboard, and control it all with a harmony one and ir repeater.
    The only problem is that when the 605 was on show i used to alter the LFE and center channel depending on movie and time of night using 'CH SEL' and 'level-'/'level+'. The display on the 605 displays this info fine, but i wondered if there is a way for this info to be displayed on my TV? So I don't have to keep opening the cupboard doors to change level on these channels.
    I can't find anything in the manual and I can't seem to find any info on this forum.
    Any replies are always appreciated Thanks
    Leon
    * The onkyo is connected to the Tv with a HDMI lead.
  2. leo79
    leo79
    Mar 9, 2008
    1,218
    116
    +582
    Anyone?:)
  3. topcourier
    topcourier
    Jul 8, 2008
    140
    +16
    On the remote go input output assign, scroll through to HDMI monitor out( select yes) you should now see it on the tv so you can do all the adjustments on the screen :smashin:
