Onkyo 505E
Discussion in 'AV Receivers & Amplifiers' started by bertiespiv, Jan 23, 2008.
Tags:
  1. bertiespiv
    bertiespiv
    Jan 12, 2008
    16
    Any you guys connected up the 505E to aPanasonic plasma (TH42Z700) and PS3?
  2. gazeele
    gazeele
    no but i do have one connected to a panasonic viera lcd and a ps3:thumbsup:
  3. bertiespiv
    bertiespiv
    Jan 12, 2008
    16
    Thats close enough! How have you connected up and how is the overall system performing.
  4. gazeele
    gazeele
    HDMI from PS3 to back of TV and Optical Cable from PS3 to Amp (then make sure that you adjust your sound settings on your PS3 so it outputs via the optical and not the HDMI).
    If your TV has an optical out you can also run a cable to the second optical on your amp (i do this for everything else thats plugged into the TV, ie: SKY) - if you do output your TV audio to the amp though remember to turn the TV volume down to zero.
    I have some JAMO speakers and being and amp/speaker newb the sound is awesome.
    Hope this helps.:thumbsup:
