Tom Tom
Hey,
I know this amp is old but I am only just getting around to adding more than two speakers!
I bought today a BK Gemini Sub from these very forums, had a demo the sub was working and all was well.
So I get home and notice when watching Sky Go on the Xbox 360, the sub was not really doing anything (although it seemed to earlier when I tried the PS3 with a bluray)
Now the PS3 is connected by an optical cable where as the 360 is just Phono (stereo) sound.
I would have thought the sub would have worked anyway but it seems to remain quiet when on the 360.
I did the audio set up as suggested by the Onkyo using the mic they provide.
I just wanted to know if there was anything I need to test or do to see where it is falling down.
When I turn the sub volume up it has a hum, but one of those that you would say is not the good kind. (kinda like earth loop sound if you know what I mean)
Also I have most of my hifi set up to be turned off by the strip plug switch at night. Should I turn the Sub off at it's own switch first before starting and shutting down the rest of the kit?
Tom
Tom
