onkyo 505 set up help
Discussion in 'AV Receivers & Amplifiers' started by mcfc1664, Jan 23, 2008.
Tags:
  1. mcfc1664
    mcfc1664
    just bought a new system and would like some
    help and advice on set up please
    had a sony all in 1 system and have upgraded to..
    onkyo 405 dvd player..1 hdmi connection
    onkyo 505 3 hdmi connection
    sky hd box 1 hdmi connection
    kef kht 1005 speakers
    the tv is a samsung 50inch with 2 hdmi and 2 scart
    need advice on what cables i need and what is best
    to connect with hdmi as the tv only has 2 hdmi
    cheers
  2. sp_harris
    sp_harris
    Feb 13, 2006
    582
    +60
    Plug the DVD into the TV using a HDMI cable, then an optical cable from DVD to Amp. Plug Sky HD into TV using HDMI lead, then optical from Sky to Amp. Change settings in Sky services menu to allow dolby audio output.
    You could put the HDMI's from the Sky and DVD to the amp then have 1 from amp to TV, but the only difference would be slightly simpler switching so I wouldn't bother.
    Obviously be careful with the speakers making sure the wires are correct at both ends (positive to amp and speaker). Also make sure the back speakers are connected to the surround speaker posts on the amp and not the surround backs.
    i think you will need a co-axial cable for the sub woofer that goes to a specific connection on the back of the amp - someone else can confirm this.
