onkyo 505 help please
tabs
Joined
Apr 3, 2005
Messages
1,974
Reaction score
129
Points
733
Age
49
Location
warks
im not sure whether this thread should go in recievers, ps3 or projectors .. anyway
i have some turtle beach wired headphones / mic, that i use to play on my ps3,
i have just bought an optoma projector and onkyo 505 amp, now then ..
i used to pop the headphones into the tv when on the ps3, but now i have the pj and amp setup i pop the headphones into the amp im getting nothing .. not a dickie bird, i just cant see where im going wrong, help please before i pull my hair out .. or the mrs's :D
thanks
The amp probably mutes the TV audio (including headphone socket) when it's on. Plug your headphones into the amp instead.
thanks for the reply, i am plugging the headphones into the amp but getting nothing
Sorry, you did say that in your initial post.
OK, can you check that the headphones work by plugging them into something else? Then, with sound playing through the amplifier and speakers, plug the headphones in and confirm that the speakers turn off. Do you need to increase the volume control to get the headphones working, perhaps? Also, check out page 47 of the manual for how to set headphone volume offsets.
Also, as it's an Onkyo it's worth turning the power off at the mains socket for few seconds and then back on again in order to achieve a cold start.
cheers steve, i'll give it a whirl mate, thanks :smashin:
StormAudio ISR Fusion 20 AV Receiver - review coming soon #HomeCinema #Amplifier #VideoShort
Back
