onky705 + loud humming from sub
Discussion in 'AV Receivers & Amplifiers' started by andicapped, Jan 20, 2008.
  1. andicapped
    andicapped
    Jun 7, 2006
    1,668
    manchester
    +74
    it's very annoying. i'm going to do a full reset-up of the amp but i'm looking for suggestions as to what it can be
    help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  2. johnfbr
    johnfbr
    Jul 6, 2005
    155
    Bristol
    +15
    I Had this as well, see this thread: http://www.avsforum.com/avs-vb/showthread.php?t=931586. Suggest you check cables, try disconnecting pieces of kit and try changing the mains plugs that in points to rule out these as causes. I ended up changing to 805 and am pleased I did because sound quality much improved.
  3. Mark.Yudkin
    Mark.Yudkin
    Sep 19, 2007
    10,018
    Zurich, CH
    +1,536
    Assuming it isn't the fault mention by johnfbr, it's probably a ground loop (gives a nice 50Hz hum). Before we start on the full mouse hunt, let's try the most common causes:
    1) disconnect all coax aerials (cable, satellite, whatever) and see if that helps.
    2) If 1) doesn't help, plug the sub into the same wall socket as the amp.
    Then come back with the results.
  4. andicapped
    andicapped
    Jun 7, 2006
    1,668
    manchester
    +74
    ok i'll try all your suggestions. also just to mention it is only happening (noticable) when watching sky HD (some of the less quality channels)
  5. johnfbr
    johnfbr
    Jul 6, 2005
    155
    Bristol
    +15
    Does not sound like the problem I had. Mine was a low but annoying hum on all sources. Assume you are connected to SkyHD via optical ? Try changing the optical input used. If you have another optical lead try taht.
  6. andicapped
    andicapped
    Jun 7, 2006
    1,668
    manchester
    +74
    thanks for your help guys, think i've sorted it. i feel a bit silly really. i changed the ground switch on my sub and that seems to have solved it. :oops:
  7. Mark.Yudkin
    Mark.Yudkin
    Sep 19, 2007
    10,018
    Zurich, CH
    +1,536
    Since it's Sky related, you'll get it again next time you connect grounded equipment. The simplest solution is to insert a coaxial ground loop isolator between the Sky box and the coaxial aerial lead.
  8. andicapped
    andicapped
    Jun 7, 2006
    1,668
    manchester
    +74
    where do i get one of them from?
  9. jordandy512
    jordandy512
    Aug 29, 2007
    2,127
    West Mids
    +94
    Hi, I get a hum from my sub when audessy is running, switch it off and it goes away. This leads me to beleive the sub is fine and the amp is causing the hum.
    Anyone got an idea on this?
    Andy
  10. johnfbr
    johnfbr
    Jul 6, 2005
    155
    Bristol
    +15
    See my earlier post and the link. Turning audyssey off certainly decreased the hum I was experiencing but did not fuly cure. Also wanted to use audysey functionality
  11. Mark.Yudkin
    Mark.Yudkin
    Sep 19, 2007
    10,018
    Zurich, CH
    +1,536
    Your dealer or basically anywhere that sells TV's. I can't be more specific, as I don't like in UK. Here's a link that will give you an idea.
