Oneforall Mosaic and Digifusion Freeview
Discussion in 'Home Cinema Control & Remote Controls' started by richjthorpe, Nov 2, 2004.
  1. richjthorpe
    richjthorpe
    Aug 2, 2004
    2,031
    41
    dat london
    Hi all,
    Does anyone know the code for a Digifusion FVRT100 freeview box for a Oneforall Mosaic ?
    TIA,
    Richie.
  2. smerkderk
    smerkderk
    Oct 15, 2004
    44
    Berko
    Rich,
    If you go on the one for all web site and go to :
    Products - support
    Uni remotes
    pick the mosaic - and log in (assuming you are a member, if not quickly sign up)
    then go to satalite receivers then pick digifusion - you can download and upgrade from there. not sure if thsi will work?
    The easier route would be to use the learn facility on the remote (assuming you have the original remote?)
  3. smerkderk
    smerkderk
    Oct 15, 2004
    44
    Berko
    Or you could try one of these codes?? 1581 1587
  4. rutteger
    rutteger
    Apr 29, 2004
    452
    +7
    Out of interest do these oneforall codes include a discrete on or off ?
