OneforAll 7556 (Help with Sony dav-dz260 and Mirai TV)
akachris1
I bought a Oneforall remote the other day but cant get it to work properly.
I used the codes provided in the manual and on thier website but with no luck.
Then I did the blind search thing and while searching the DVD function for the Sony, the Mirai TV responded. So I took note of the code and keep going but the Sony never responded.
So under the TV function, I typed in the code I accidently came across earlier but nothing happened.
The TV only responds under the DVD button, which is no good.
Any help would be appreciated.
- Mirai DTL-632E500
- Sony DAV-DZ260
- OneForAll URC-7556
M
mav617
I bought one today - and it's going straight back in the morning. I know that doesn't help, sorry, but it won't work anything other than my Toshiba tv.
