One4all code needed for Tosh 210 DVD player!
Discussion in 'Home Cinema Control & Remote Controls' started by Noel, Oct 20, 2001.
  1. Noel
    Noel
    Dec 18, 2000
    421
    +8
    Does anyone know this by any chance? The remote is the URC-7540 4 in 1 and I want to assign the Tosh to "aux". There are no codes in the book.
    Many thanks,
    Noel
  2. simon1
    simon1
    Jul 7, 2001
    918
    28
    Teesside
    +58
    It is probably because there isn't a preprogrammed code in it's memory. This was the case with me and my Hitachi DVD. OFA suggested I buy the OFA 6, which I did.
    Again, there was no code for my player in it's memory. But cos it has a built in modem, they were able to update the OFA 6 over the phone simply by placing the earpiece next to the remote - very clever!
    Although I got it working just fine, I decided to send the OFA 6 back cos I didn't like the layout and size of it.
    I've ended up buying the Philips RU880 learning/preprogrammed remote which is absolutely superb for just £41. See my earlier post 'Pronto's nephew'
  3. Noel
    Noel
    Dec 18, 2000
    421
    +8
    Excellent. Thanks Simon. It's only for the bedroom so we can control some of the downstairs kit, but I've got a Pronto downstairs and wasn't that impressed with the OFA. Nephew of Pronto seems a sensible step.....!
  4. Noel
    Noel
    Dec 18, 2000
    421
    +8
    Simon,
    Got my 880 from LetsAutomate today and it's excellent, just what I needed. Thanks for the recommendation!
    Noel
  5. simon1
    simon1
    Jul 7, 2001
    918
    28
    Teesside
    +58
    Pleased you liked it Noel.
    I had tried the one for alls and I also tried the X10 8 in one remote and they feel like cheap, nasty chinese cr*p.
    Whereas the philips seems like a hundred quids worth. Bloody good value.
    My Mrs likes it, especially now we have the lamp dimmer modules. No more fiddling about finding the swich. With the press of one button we can have them all on/off or dim them individualy.
