One stop digital camcoder and still camera?
Discussion in 'Photography Forums' started by Blenky, Mar 21, 2005.
  1. Blenky
    Blenky
    Jul 27, 2000
    406
    Hove, England
    +92
    I currently still use an aging (nearly seven years old) analogue camcorder and a digital camera which also is showing its age.
    Ideally I would like to replace both. However it would be great to buy an all in one camcorder/camera solution.
    Is there currently a camcorder that will take good still photos? I would like one that takes at least 4 mega pixels. Or is this still not an option?
  2. ElchenUK
    ElchenUK
    it depends on what your budget is.
    for a tad under a grand you could get the everio MC500 which is a 5 megapixel camera and a hardisk camcorder to boot.
  3. Blenky
    Blenky
    Jul 27, 2000
    406
    Hove, England
    +92
    Yikes - too much for me but thats what I'm looking for. Seems I'll have to wait until the technology matures a little bit more.
  4. ElchenUK
    ElchenUK
    probably a good idea to wait a while as the technology of trying accomodate a good lens for video and still imagery is quite expensive at the moment.
    I did notice a sanyo player that is much cheaper and does 4 megapixel - unfortunately it looks like something you would get from a chrismas cracker!
    it also only does mpg4 as opposed to the everio's mpeg2
    http://www.camcorderinfo.com/conten...-Camcorder-with-4-Megapixel-Sensor-VPC-C4.htm
