One set of speakers for cinema and hi-fi ?
Discussion in 'AV Receivers & Amplifiers' started by chris mooij, Dec 29, 2003.
  1. chris mooij
    chris mooij
    I have a Sherwood RD-6106R cinema amp and Marantz hi-fi amp. My speakers are Mordant short 608s. I would like to run both cinema and hi-fi through the same speakers. I have tried the pre-out on the Sherwood to route the signal through the hi-fi amp and then drive the speakers from the hi-fi amp. This did not seem to work - it seems no signal received.
    Can anybody help?
  2. buns
    buns
    Apr 29, 2001
    6,066
    58
    Belfast
    to what input on the marantz amp did you connect?
    ad
  3. markwww673
    markwww673
    Oct 31, 2003
    2,945
    103
    Midlands
    +321
    I connect both a pioneer 2001AV amp and a marantz PM4000 to one set of speakers using a QED ML19 switching unit to select which box controls the speakers. It takes a little more speaker cable as you run 2 lots of cables from the source boxes one from each source and finally one set of cables to the speakers themselves.
    Hope this helps
    Mark...
  4. buns
    buns
    Apr 29, 2001
    6,066
    58
    Belfast
    it is much easier than that.... chris sounds like he was on the right lines..... preout to the amp and use the stereo amp for powering the front speakers..... but its maybe simply a case of how he has it connected
    ad
  5. Reiner
    Reiner
    Jul 16, 2000
    3,315
    61
    Germany
    +13
    Sounds ok to me. Just to be sure though: did you use the front pre-outs?
    At the stereo-amp you can use any input, e.g. AUX or CD. The speakers still connect to the AV amp of course, but the AV source (DVD player) must connect to the AV amp (digitally I rekon).
    Also try to fiddle with both volume controls, maybe the signal from the AV amp on the pre-outs is a bit weak?
  6. dood
    dood
    Aug 4, 2000
    943
    28
    Hobart
    +38
    Reiner, you mean the speakers are connected to the stereo amp not AV amp. Front speakers to stereo amp, centre and surround speakers to AV amp.
  7. higenbs1
    higenbs1
    Aug 16, 2002
    460
    +11
    I've always wondered, what the difference between pre-out sockets, and tape loop out sockets. Don't they do the same thing?
