One quick question...
Discussion in 'Headphones, Earphones & Portable Music' started by nico_192, Jul 18, 2005.
  1. nico_192
    nico_192
    is it ok to have an mp3 player (zen touch in this case) plugged into the wall charger while transferring files? I noticed while transffering 2,000 files that the zen touch's battery ran out after just a couple hours, so i then decided to have it plugged into the wal mount to finish the transffers. I then found that after just around 20 min. or so, the unit became VERY warm. Should i do this, or just re charge the unit before finishing transfering the rest of my files?
  2. David Mackenzie
    David Mackenzie
    Aug 28, 2003
    10,213
    Glasgow, UK
    +1,312
    Yup, there's no problem with leaving it plugged in. If anything, it would be the safer option.
