One pair of 5.1 speakers - two PC's
Discussion in 'Desktop & Laptop Computers Forum' started by firstwave, Oct 5, 2004.
  1. firstwave
    firstwave
    Hi.
    Been looking for some form of switch box to do the following, but having no luck so far. Anyone come across anything that will do the trick?
    Scenario:
    Two PC's each with audidy soundcards, using the three jack output.
    One set of 5.1 speakers again using the three jacks as input.
    What I am looking for is some form of switch box that will accept the two sound card outputs as the inputs, and the speakers as the output. So I can switch between the two soundcards depending on what PC I am using.
    So far I have managed to find basic switchboxes, with single jack per input. Surely there must be a triple jack input/output switchbox somewhere.
    Many thanks for any assiatance in advance.
    Darren
  2. firstwave
    firstwave
    Anyone got any ideas?
  3. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    I'd be surprised if such a product exists, I doubt sufficient users would have such a requirement to make such a product viable commercially. I certainly have never seen anything like it at all.
    Of course, I could be proved wrong. :)
  4. H4r7y
    H4r7y
    Jun 17, 2003
    1,713
    39
    Nottingham
    any chance of using the optical output on each pc?
    you can get optical switches
  5. firstwave
    firstwave
    Nice thought H4r7y, but the speakers don't have optical in - they are the creative speakers that only have the three jack inputs.
    Thanks for the idea anyway.
  6. H4r7y
    H4r7y
    Jun 17, 2003
    1,713
    39
    Nottingham
    why not just get 3 'y' leads then if theyre rca type connectors?
    you could connect both up at once but i wouldnt use both at the same time!
