one little annoyance
Discussion in 'PS Vita Forum' started by matt_du_man, Sep 12, 2005.
Tags:
  1. matt_du_man
    matt_du_man
    May 15, 2005
    26
    3
    one little thing i noticed, is when you are listening to music, you can press select to get out of it while still listening to your music and browse the menu.
    yet, if you click on somthing your music stops, i mean how easy would it be to let your music keep playing while entering system settings for example.
    hopefully they add this feature in a version upgrade.
  2. Steven
    Steven
    Senior Moderator
    Feb 1, 2005
    36,436
    +6,224
    Well on the other hand, if you forget to have hold on, and buttons are pressed accidently, you'll be able to stop altering system settings mistakedly
  3. matt_du_man
    matt_du_man
    May 15, 2005
    26
    3
    good, point, but i bet that there are not that many people that that would be a problem for, but i bet quite a few would like this feature in the next update. i know i do.
