one for all
Discussion in 'AV Receivers & Amplifiers' started by nigelcraft, Oct 2, 2003.
  1. nigelcraft
    nigelcraft
    Mar 18, 2001
    79
    uk
    does anyone know if i can use one of those one for all remotes you can buy for use on my technics sa-dx940 dolby digital reciever as my controller is broke and i cannot find a replacement on this earth anywhere at all and no places i have sent an email to will reply,or can you only use these one for all remotes on tvs and videos
  2. Garrett
    Garrett
    Apr 21, 2001
    39,872
    2
    167
    The best thief you’ll never see.
    +6,531
    I think you can use them on most things I use one for TV, Video, CD.
    Unfortunately I think mine is an old one and will not work my Sky sat although it worked the previous non digital one. It also will not work my mini-disk player.
    There site is here
  3. Tracey
    Tracey
    do you not need the original remote to copy the codes, or are you talking about a remote that you can enter a code number and it automatically controls your kit?
  4. alexs2
    alexs2
    Nov 13, 2002
    13,957
    +1,671
    You may want to take a look round www.remotecentral.com lots of useful info and reviews as well as codes etc there.
  5. Garrett
    Garrett
    Apr 21, 2001
    39,872
    2
    167
    +6,531
    All For One you can or could program any of the user buttons to what ever you liked if there was a code for it. In My case I got the remote long before mini disc and digital satellite came out so there will be non of them codes in its memory. I think some you can ring them up and they send something down the telephone line and it upgrades the remote.
    Best thing to do is if you get it in a shop make sure you can take it back if it does not work the equipment you want.
    This is taken from there web site is the info on there One For All 5 (URC-7552)
    • Ready to operate all brands and all features of TVs, video recorders, DVD players, satellite receivers/cable boxes, CD-players and amplifiers/tuners (incl. surround sound)
    • Pre-programmed and learnable
    • Has a backlit LCD with clock and alarm
    • 4 custom keys under special flip down door for adding additional functions of the origional remote and macros
    • Features include: menu, mode indicator, teletext, fastext, surround sound control, colour/brightness control and Key Magic
    • Built-in modem allows new codes to be added by phone or via the the internet; will never become obselete
    • Ergonomic design with an attractive control island for easy use
  6. andymc
    andymc
    Sep 18, 2003
    266
    Bedford
    +15
    I have a a Mosaic and it can learn anything you want it to and you label the buttons as you want BUT you need to have a working remote from it to learn from.
    They have a website www.oneforall.com and do advertise that you can dowload new codes for certain remotes and things but I have yet to find out where on the website you can do this.
    Richer Sounds are/were doing the Mosaic for about £50 and its a nice piece of kit
    Andy C
  7. nigelcraft
    nigelcraft
    Mar 18, 2001
    79
    uk
    thanks to all ill look into it straight away
    thanks again
