One for all remote controls
Discussion in 'Home Cinema Control & Remote Controls' started by mygirllollipop, Dec 31, 2004.
  1. mygirllollipop
    mygirllollipop
    Bought a one for all remote from Argos but it doesn't work with my brand of TV. Does anyone know where else I can try?
  2. The Robman
    The Robman
    Which OFA did you get? If it's one of the upgradeable ones you might be able to load an upgade over the phone or send it in for an upgrade. If you mention the model number of the remote and the model/brand of the TV I might be able to help further.
  3. mygirllollipop
    mygirllollipop
    Only just got your post Rob. Cheers - will look in to that site.
