One For All 5 & dvd codes
Discussion in 'Home Cinema Control & Remote Controls' started by Rindless, Mar 2, 2003.
  1. Rindless
    Rindless
    Dec 15, 2001
    680
    +4
    I have a One For All 5 (URC - 7550)
    What is the code that will enable it to run a Panasonic DVD LV75 Portable DVD player ?
    The original dvd remote is broken so the learning function can not be used.
    If this OneForAll remote can not be used, what is the cheapest alternative ? :confused:
  2. auldendunn
    auldendunn
    Nov 3, 2002
    77
    Fife
    The Panasonic code for OFA6 is 0490.
    Have you tried search method?
    A call to OFA will probably resolve it if these don't. :)
    HTH
