Question One door or two?
Triggaaar
When building your cinema room in your house, and making a fair chunk of effort to provide sound proof the room (to reduce sounds both entering and leaving the room), is it best to have 1 really heavy door (eg, a fire door with a sheet of MDF greenglued and screwed on), or have 2 separate fire doors (opening in opposite directions)?
AmericanRodeo
To be honest, we've done both on builds and I would say it depends on the scale of the build.
Our double door one was a major £100k 8 person room full of JBL synth kit including 4 x 18" subs! Its a hoot and with both doors shut very little leaks out.
Others have been £30/40k rooms and with lesser amplification, speakers and subs. Nothing much leaked out because the single door was snug and sound deadened on the inside.
Which ever you decide, get the door fitting snug, with a definitive pull to cluck onto its latch.
Triggaaar
Thank you :) Well my room and budget is a lot smaller, but there may still be 4 quite large subs in there :) I'm building a room within the room in an effort to soundproof. If going for 1 door, is it better to put it on the inner skin (and therefore opening into the room) or on the outer, original skin?
Will do, thanks.
Harkon321
Two doors are better as you get isolation and an air gap - with a single door you don't. You build it so they open opposite ways and close on to each other, with a small gap inbetween. (Like a studio).
If you've not seen it I've recommend Rod Gervais's book on studio building.
Triggaaar
Well two doors are obviously capable of giving better sound insulation. I guess my question is really how much better it is/whether it's worth it. That will depend on how far you've gone with everything else, and AmericanAudio suggests that a single door is suitable for most builds.
I've not read it, but I've read many threads which have used his book as their inspiration, so I feel like I have read it :)
Harkon321
Initially the question was, which is best. The answer to that is straight forward, the two doors will easily outperform a single door as they have a decoupled air gap. Even some of the most expensive and complex builds on here say that the weakest point is the door.
How much, that's hard to quantify, so many variables - I don't know if anyone has ever run the numbers.
Can't you install a single heavy fire door, increase mass, add Greenglue if needed. Then if it's not enough, then do the communicating door.
I'm going for one heavy door with seals and hope it'll be enough. Only other option I've seen is fixing two doors together to create one really thick, heavy door.
Triggaaar
Yes I agree.
I was angle grinding the opening today - that is a lot of dust. I was thinking of starting with the door on the inside of the room, and later adding one on the outside if needed. One minor issue is that I'd put a cheaper door on the inside if I was having two, but that's no bid deal. If having two, I presume you put the hinges on the same side as each other (obviously with the doors opening away from each other).
Where are you getting you seals from?
Is that any better than adding a sheet of mdf?
Harkon321
You can do either. If you've got enough gap between then you can go same way, or you can have then hinged opposite, so the handles don't clash.
Not a clue, so if you get some let me know. We are only at the laying brick and block stage, so just decided on opening size and told them I want a Fire Door at the moment.
It's just more mass I guess, similar idea. Again, the amount of people who have done this is very small so hard to get data. I've seen some crazy homemade doors on AVS.
Triggaaar
I've just checked out your thread. Wow it's moving fast. I think I recongnise the sketchup drawings of your kitchen. I think you posted something similar a year or so ago, maybe before you had planning?
Interesting to read kbarnes's opinion that it wasn't worth you adding the sound isolation (due to cost and space loss). I assume he'd say similar about my plans, and I have wondered whether it's worth the extra hassle and cost, but I'm going ahead with it (I've already got the timber).
I note you got some green glue on the cheap. Could you recommend how I try and do the same?
Harkon321
