One dish, 2 feeds?
Discussion in 'Satellite TV, Sky TV & FreeSat' started by andimac101, May 5, 2007.
  1. andimac101
    andimac101
    I currently have sky + running just to my front room. Is it possible to get another feed from my dish to a 2nd room, buy a second hand box and enjoy free to air sky in the 2nd room without having to pay for the multi room subscription?
  2. madhouse
    madhouse
    Nov 11, 2005
    399
    28
    Bawtry nr. Doncaster / Wiesbaden (Germany)
    +72
    Hiya,
    shouldn't be a problem at all - you can replace the LNB, which is probably a single LNB, with a double LNB. This means you will run 2 cables from the LNB, so you'd just de-attach the existing one you have from the single LNB and re-attach to the double. You can take a second cable to the other room and do as you described - buy a second sky digibox and either enjoy bbc, itv and others from the start, or you can buy a free to view card from sky that also opens up channel 4 and five for you (one time fee of around 20GBP).
    Cheers,
    Simon
  3. andimac101
    andimac101
    Thanks,
    If I bought a second hand digibox that had a card with it, will it pick up channel4 OK?, or will I have to buy one separately and register it?
  4. nigelbb
    nigelbb
    Apr 4, 2005
    5,309
    103
    +491
    As you have Sky+ you already have two connections to that. Your dish almost certainly has a quad LNB with two spare connections.
    If the card is working then it will stay working. You may find it cheaper & easier to pay 20 pounds for your own card as they do sell for more than that to ex-pats starved of UK TV.
  5. TeenSpirit
    TeenSpirit
    Aug 13, 2006
    1,366
    48
    +91
    We have a spare Sky+ box as we have upgraded to Sky HD in the lounge.
    I enquired this week as to having Sky in the bedroom, utilising the old box and Sky will NOT quote for installation without supplying the equipment - a local Sky engineer wants £60 to run the 2 cables from dish to bedroom and Sky charge £49 for a basic Sky digi box with free installation or £99 for Sky+ box with free installation the you can pay £10 a month for multiroom to enable you to watch same package as you watch in the lounge on your main box.
    Decided to buy a video sender which I am currently having a nightmare setting up (see my other posts)- wish I'd just gone for the installation locally and purchased a new Sky card :(
    Hope this helps :)
  6. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    Mrs Signs, you are right, you should have paid the £60. For £99, sky will throw the wires in through a hole in the wall, if you can bribe them to climb a ladder in the 1st place, and will make your box call back with an extension they run up the stairs, and take away with them. The £60 man would probably tack it all in place neatly, and for a big smile, a cup of tea and £10 would make you a new telephone socket where you need it.
  7. TeenSpirit
    TeenSpirit
    Aug 13, 2006
    1,366
    48
    +91
    Now decided to sell Sky+ box and wait until we get a new tv with built in freeview and wire aerial from roof into bedroom :thumbsup:
