Hi All,
I have a question that Samsung seem completely unable to answer.
I have a Samsung Frame - UE55LS03N which is wall mounted. All I'm trying to find out is whether the One Connect cable that shipped with the UE55LS03N TV is compatible with a newer (and larger) QE75LS03A (or any other 75" Frame) ?
The existing cable is routed through the wall and I don't want to have to try and route a new cable. What I'm trying to find out is exactly what 75" Frame models are compatible with the existing cable. I can replace the One Connect box and Panel, I just can't replace the cable (without serious disruption).
I've tried Samsung support and Richer Sounds, both just say "we don't know".
Any help would really be appreciated.
Thanks,
Ryan
Thanks,
Ryan
