Question One Connect Cable Wall Conduit
Grant29
I am looking to a purchase a Samsung 2019 "The Frame" TV. the house is currently under construction so I have chance to get a conduit placed into the wall to run the one connect cable to the TV mounted on the wall. What is the minimum size conduit required to fit the connectors through?
I found this documentation that shows the plug sizes:
MOLDING PLUG SIZE (W x H x D): [TV] 1.89 x 3.34 x 0.44 ; [OC] 1.15 x 2.84 x 0.54:
https://image-us.samsung.com/Samsun...Invisible_Connection_Spec_Sheet_R2_051719.pdf
MOLDING PLUG SIZE (W x H x D): [TV] 1.77 x 3.34 x 0.38 ; [OC] 0.99 x 2.76 x 0.54
Can anyone with installation experience recommend a wall conduit diameter that will work easily?
Also, at the bottom of each document it states for the 15m cable: "*This optional longer length cable is not designed to meet in-wall installation codes"
Does in-wall mean the same as "in conduit"?
Thanks!
JohnS33031
On a related note, I understand that if the one connect is the model that also sends power to the TV, then the cable is not rated for "in wall" use. Does that inlcude not running it down a pvc pipe? I do have an AV outlet up behind the TV . Does anyone know if the larger one connect power units can be placed behind the TV?
