Question One connect box 65ks9000
Discussion in 'Samsung TVs Forum' started by Kodelord, Feb 22, 2018.
  1. Kodelord
    Kodelord
    Nov 27, 2017
    24
    3
    London
    +6
    I have bought a 65ks9000 tv on ebay- bit disappointingly, wasn't clearly stated that the one connect isn't included.
    In any case, if i were to get a one connect box for myself, what do i need to look out for? Is there a variation in compatibility between the various box models? There seems to be a big variation in prices on ebay -what should I expect to pay for a compatible box?
  2. Kodelord
    Kodelord
    Nov 27, 2017
    24
    3
    London
    +6
    Bump... Anyone?
    And two more questions.. Will a ks8000 or other screen size TV's stand work with this one?
    What is the best way to check the 4k and hdr works if the seller doesn't have the appropriate sources to check. Can I get hdr clips that I can take on USB and will the tv play them?
  3. crockett
    crockett
    Nov 7, 2005
    692
    43
    +144
    From the looks of it the part no you should be looking for is BN91-17814H and this One Connect mini box works with models UE49KS8000,UE55KS8000,UE65KS8000, UE75KS8000,UE49KS9000,UE55KS9000,UE65KS9000,UE78KS9000 (not the 7000 KS series). You should be able to pick one up for £40+ but if its used make sure you get the cable as well too!
  4. Kodelord
    Kodelord
    Nov 27, 2017
    24
    3
    London
    +6
    So, I am going to pick up a 65 ks9000 I won on eBay, the coming weekend.
    The seller is selling without the one connect box, as mentioned above.
    Any tips on what to look out for while testing the tv? Any recommendations on clips and other test videos?
    The seller will connect to a one connect box for testing but won't be providing it.
