Ondigital remote codes
Discussion in 'Satellite TV, Sky TV & FreeSat' started by Beddie, May 27, 2001.
  1. Beddie
    Beddie
    Jul 19, 2000
    165
    England
    +13
    Can you help me out? I need to know how to change my Philips Ondigital remote control so that it operates a Toshiba TV.
    Do you know what the code is, and how to enter it into the remote?
  2. Tel boy
    Tel boy
    Apr 2, 2001
    147
    UK-North East
    +5
    Beddie, is this any use M8,
    Setting up the remote to control your TV
    1. Turn on the TV you wish to control
    2. Look on your Philips remote and find the Vol. -and P + keys in the TV section
    3. Simultaneously hold these buttons down for at least 4 seconds
    4. Enter the 3-digit code for your TV
    5. Aim the remote at the TV and press the OFF button your TV should now go into standby.
    6. If the TV does not respond try again using a different code for that manufacturer
    Tosh codes: 062.or 063.or 097.or 270.
    hope this helps M8
    Regards Tel boy. :)
  3. Beddie
    Beddie
    Jul 19, 2000
    165
    England
    +13
    Sorted! :)
    Cheers mate, thanks for your help :cool:
  4. Tel boy
    Tel boy
    Apr 2, 2001
    147
    UK-North East
    +5
    Beddie, dose your remote control your VCR also, have codes/instructions,if U want just post. Glad to help. Tel. :)
