OnDigital pace box
Discussion in 'Satellite TV, Sky TV & FreeSat' started by petrolhead, Jan 21, 2004.
  1. petrolhead
    petrolhead
    Mar 29, 2002
    4,772
    Newcastle
    +112
    I have the OnDigital page box which I use for freeview.
    Does anyone have a userguide or info.
    I want to know if the scart can output S-VHS
  2. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,379
    Somewhere in South Yorkshire
    +5,765
    You can find this out by checking the menu. There is a 'TV Standard' setting in there. If I recall correctly, the options are only RGB and Composite. But yours may differ. Clearly, if SVideo is an option in the menu, then I guess it's enabled. There is nothing explicit in the manual.
  3. petrolhead
    petrolhead
    Mar 29, 2002
    4,772
    Newcastle
    +112
    Cheers, will check this tonight :)
  4. petrolhead
    petrolhead
    Mar 29, 2002
    4,772
    Newcastle
    +112
    Slight delay
    The Pace does not support S-Video
    So have decided on a Pioneer.
    Do you think that I will notice an improvement over the Pace?
    If this is a favorable option what do you thing the Pace is worth if I sell it.
  5. LV426
    LV426
    Jul 14, 2000
    13,379
    +5,765
    If your question is about watching (rather than recording) I recommend RGB as the signal protocol - assuming your TV will take RGB. It is a little better than SVideo. In terms of overall box picture quality then I'd say the Pioneer and Pace 735 are about equal, and both are better than Philips or Nokia equivalents.
  6. petrolhead
    petrolhead
    Mar 29, 2002
    4,772
    Newcastle
    +112
    I will watch the signal thro a TV (RGB) and a projector hence the need for S-Video. The component on the PJ is already being used.
    So there will be no picture benefit?
  7. petrolhead
    petrolhead
    Mar 29, 2002
    4,772
    Newcastle
    +112
    Sorry to resurect this but checking the menu again.
    TV is either RGB or Composite and Video is either pal1 or SVideo
    Pal1, whats that?
  8. Chris Muriel
    Chris Muriel
    Jun 14, 2002
    7,257
    Manchester
    +753
    That will be PAL I (standard used for UK rather than PAL B/G used on the continent with different sound subcarrier frequency). It's a composite video standard (Cvbs).
    Chris Muriel, Manchester
  9. petrolhead
    petrolhead
    Mar 29, 2002
    4,772
    Newcastle
    +112
  10. andyMallion
    andyMallion
    The Pace DTR 730/735 sel for around £30 on ebay
  11. petrolhead
    petrolhead
    Mar 29, 2002
    4,772
    Newcastle
    +112
    I'm not selling mine E)
  12. MartinImber
    MartinImber
    Apr 5, 2001
    3,854
    71
    Worcester
    +21
    AFAIR none of the Ondodgy boxes did SVid
    Choices are
    1) COmponent switch and Netgem IPlayer
    2) BOx with SVId - eg most Pace Freeview boxes
  13. petrolhead
    petrolhead
    Mar 29, 2002
    4,772
    Newcastle
    +112
    But why is there the option under Video for Svid?
  14. petrolhead
    petrolhead
    Mar 29, 2002
    4,772
    Newcastle
    +112
    I now have my Iscan HD+ and want to input the signal from my OnDigital box.
    As LV426 said earlier there is a setting for the TV standard and this is set to RGB but when I connect the box to my iscan using a scart to RGB + sync I got no picture.
    I have checked the lead by connecting to the DVD player and all is fine
    I am beginiing to wonder if the digi box actually outputs RGB. I have tested the ican using the composite and it works fine and actually improved the picture and would think that feeding the ican RGB will be even beter
  15. LV426
    LV426
    Jul 14, 2000
    13,379
    +5,765
    Mine certainly does (connected by fully wired SCART to a TV). At least, if I change it to PAL/Composite (whatever) then there is a very noticeable drop in PQ. So I guess it is doing..... This statement is true for both Pioneer and Pace 735 boxes.
  16. petrolhead
    petrolhead
    Mar 29, 2002
    4,772
    Newcastle
    +112
    Very strange. Will check agin against tv but my scart to RGB+Sync does not work to the scaller and neither does the Pace Twin but to chech the cable i connected to DVD and all ok
  17. petrolhead
    petrolhead
    Mar 29, 2002
    4,772
    Newcastle
    +112
    Ok checked and yes. When chaging between RGB and Comp there is a noticable difference. I noticed it more with the menu :)
