On XBox opt out can I get Dolby & DTS??
Discussion in 'Blu-ray & DVD Players & Recorders' started by monkeychicken, Feb 4, 2003.
  1. monkeychicken
    monkeychicken
    Just a quickie,
    I'm in the process of buying a surround system with optical in for dolby digital and DTS etc. I'm hoping to use the x-box as a temporary measure before buying a dvd player.
    The big Q is... the optical-out that the xbox dishes out, will that allow the processor to do it's stuff??
    I've got the xbox cable with the optical out and the optical cable.
    a simple 'yes' or 'no' will do.
    MC
  2. andy572
    andy572
    Dec 4, 2002
    362
    Oop North
    Hi there.
    That'll be 'yes' :)
    You just have to return to the 'box 'dashboard', where new sound options will appear (for the DD and DTS).
    andy.
  3. DarthChris
    DarthChris
    im to am thinkin of getting an xbox
    but i couldnt find any form of digital output on idoes this mean that i can only use the xbox onboard decoder?
    2) how can i multi-region my xbox
    thanks
  4. kevenh
    kevenh
    Jul 3, 2002
    342
    19
    Royal County Of Berks...
    The XBOX comes with a standard video/audio cable that doesn't have a digital audio connection.
    You have to upgrade to an Advanced A/V cable.
    I use the Joytech one. It's alright.
    2) there are several choices. A mate of mine reckons there's a multi-region mod that plugs into the USB port! I'm not sure about that but I know there are solderless chips out there!
  5. Apocalypse
    Apocalypse
    Aug 14, 2002
    840
    19
    Sheffield
    The XBOX in it's untouched state is regionless, it fixes onto the first add on kit plugged into it and remains that region. So if you import the US DVD add on kit your XBOX will play R1 only, better than crappy Reg 2 :)
  6. bxd
    bxd
    Oct 17, 2001
    1,487
    Southampton
    +134
    I'd be a bit careful.
    I have a UK Xbox (bought around Xmas) and I've added a R1 remote with the intention of playing R1 dvd's.
    Unfortunately, the Xbox only outputs pal and won't do ntsc unless I get it chipped.
    Brian.
