On wall speakers to match plasmas
Discussion in 'Home Cinema Speakers' started by danpep, Mar 20, 2006.
  1. danpep
    danpep
    Mar 20, 2006
    38
    11
    London
    +5
    I've just mounted my charcoal framed 42" panny on the wall and want to replace my bookshelf speakers with something low profile and matching in height that I can mount on the wall.
    I like the Infinity TSS-4000 sub/sat kit which comes in charcoal (apparently) but am only able to locate one instance of this product and in the platinum finish at that in the UK. The price is on the high side but they are well reviewed speakers.
    The only other option I can find is the B&W FPM4 range. This is obviously an expensive but quality product. Unfortunately it's out of my budget :(
    Anyone have other suggestions?
    Thank you all.
  2. danpep
    danpep
    Mar 20, 2006
    38
    11
    London
    +5
