On the fly DD encoding?
Discussion in 'Desktop & Laptop Computers Forum' started by Paul D, Sep 30, 2001.
  1. Paul D
    Paul D
    Dec 27, 2000
    2,743
    Manchester
    +539
    Hi.<br />I have my PC sound card connected to my Amp via a Digital coax lead.(spdif)<br />This is fine for passing Dolby/DTS 5.1. But for games it reverts to PCM stereo.<br />I believe there are some new soundcards coming out with DD 5.1/4.1/4.0 "on the fly encoding", for games etc.<br />Anybody know when they are out?
  2. Branxx
    Branxx
    Nov 1, 2000
    810
    London, UK
    fulabeer,
    This will be of any use only of your game software is capable of generating more than 2 distictive audio channels.
    However, for a game to do this it will need to have multi-channel audio card in the PC. This would usually have analog connectors that you can connect directly to your multi-channel receiver. This would be much cheaper than AC3 encoding in real-time.
  3. Paul D
    Paul D
    Dec 27, 2000
    2,743
    Manchester
    +539
    I only ran two phono leads from the HTPC to the amp (for stereo sound etc). But know i just use one lead to pipe PCM/DD/DTS.<br />I've heard new games are comimg out that support 5.1 etc. Plus some games have four channel sound already. I just want this "four channel" to be sent to my amp digitally "4.0" etc with the one phono.<br />That way the sound card converts any multi channel game into a signal the amp can decode etc.
    This way it will save me having to lift the carpet to run four other phonos!.
  4. Stuart Wright
    Stuart Wright
    AVForums Founder Staff Member
    Jan 24, 2000
    14,606
    7
    167
    Birmingham, UK
    +10,475
    DTS have produced a SDK (software developers kit) for the PS2 to produce real time encoded 5.1 sound.
    I also know Dolby are working on a real time encoder in the software.
    I think the most likely configuration we'll see is 5.1 encoding within games for output of an optical or coax equipped sound card. That will be the most compatible with current systems.
