LittleNipper
Place holder.
Yes, they are existing and as such are fixed.Are the 4x2 beams in the diagram the existing rafters so the height is restricted to 2.3m or is this all new?
I added more info and photos to my post, you will have to be mindful of the extra depth needed for the speaker tiltYes, they are existing and as such are fixed.
They are existing ceiling joists at 355 centres with 18mm ply above screwed into them. These ceiling joists were 5.4m and then trimmed so they run the entire width of the building and are then attached to the wall top plate and bolted to the bottom of all of the roof rafters to stop any potential spread.
It is overkill from a structural point of view, but I wanted to use the area above for storage. The area above will now only be used for empty box storages, as such very little load. Also, when I plasterboard the underside of the ceiling it will essentially act as a torsion box.
So, when the ceiling speakers are put in, there face will be 'about' flush with the bottom of the ceiling.
I like that idea. That way you'd not know if I had .4 or .6 in the ceiling line. I could also do something to defuse the sound depending on how I set things out.Recesses so long as speakers are Dropped level with ceiling, it Seems like a decent idea, you could also Add a drop down fabric ceiling at a later stage to cover the whole area. i’d probably only create the slots in the extend of the Atmos area I think ceiling slots could look a distracting feature above the screen.
Exactly, plus the drop ceiling panel can hide acoustic treatments or speakers, or include a star ceiling if you want to be fancy!I like that idea. That way you'd not know if I had .4 or .6 in the ceiling line. I could also do something to defuse the sound depending on how I set things out.
Isn’t it a bit early in the thread for Amp porn photos? putting such equipment in the loft might keep the fan noise level down, or have you another plan?I will need to totally rewire the area and also bring a larger feed in. I emailed pictures of the amps to my spark. He just replied 'cock'. I've known him a long time... But come on ... they do have nice bottoms ... ( note these are not the big boy amps.... just the baby ones ).
These amps run silent. I've done some research, removed the existing fans and put a new one in you won't be able to hear them. Lab Gruppen AmpsIsn’t it a bit early in the thread for Amp porn photos? putting such equipment in the loft might keep the fan noise level down, or have you another plan?
I've already bought two 15U racks. One will be for amps and hot stuff ( and I don't mean those old mags from in the loft ) and the other for cooler running items and sources. As we have an iffy power supply I will get a UPS as we get powers glitches quite often. The amps will cope with it but less so media players, processors ect.So that’s why there’s a UK cellotex Shortage?
As you have the option and given your balanced id still consider placing the amps in a different rack tower venting to the low level stuff, so the amps don’t push the temp of the whole rack up
@Smurfin I know, I must be joining the idiots club or somtehing ;-) ( Intentional spelling )Well this is going to be a rubbish build. Who in their right mind would use proper cinema speakers for a DIY build in a garage!
/subscribed
Do what you can to get the speakers high. Also consider a layout which matches Auro 3D spec, which has the top channels lower than Dolby.Whilst the ceiling height, when finished should be about 2.3m, the Atmos height speakers I'm going to initially use with brackets will sit down about 300mm. So, what I was considering doing was to create recessed strips in the ceiling that can accommodate them.
