We're migrating the forum software to the next major version and this will require the site to be down for the best part of Monday 16th.
More details here. Apologies for the inconvenience.
On Screen Display
Discussion in 'AV Receivers & Amplifiers' started by karlak, Oct 28, 2005.
  1. karlak
    karlak
    Sep 4, 2005
    2,950
    +2,573
    Does anyone know if the OSD for the Denon 2106 and YAmaha DSP-ax757 works through the component out? I have not had an amp that uses OSD before so am unsure as to how it works - from a connectivity point.
    Also I believe that out of these 2 amps, only the Yam will Upconvert to component. Would I need a 'box of tricks' to get my SKY plus from RGB to SVIDEO in, on the amp, or is it simply a Scrt to SVIDEO cable?
  2. johnmccoy
    johnmccoy
    Jan 25, 2005
    17
    Ballynahinch
    Can't answer your OSD questions, but I can tell you that my Sky+ has an SVIDEO output on the back as well as the SCARTS - mine is a PACE v2, but I would think the newer ones would be the same.
  3. karlak
    karlak
    Sep 4, 2005
    2,950
    +2,573
    Many thanks, just checked - I have the same box as you, so the S-video is there. Never occurred to me that it would have that connection as well :)
    Just need to find out about the OSD now
  4. pragmatic
    pragmatic
    Nov 9, 2004
    12,156
    +1,647
    Most amps can't send the osd via component (infact i'd be supprised if either did), the upconversion yes take in s-video and give you component, won't look any better but means one cable convience, especialy if your pj is on the other side of the room or celing ect...
