on screen display
martin 39
Hi all just set up my old Denton 3803 in the boys room for his Xbox . Running through component . Cannot seem to get a y on screen display . It switches but says no signal . Pain really as I can not set it up properly for him as only got to speakers at the moment . Any ideas anyone can't even get it to work on amp screen . Thanks
DodgeTheViper
Do you have the Xbox assigned correctly ?
martin 39
I believe so it's set to hd . Got no problem with picture on the Xbox . Its the menus I can't get to work on the amp . So I can set speakers to large etc and turn off the speakers I'm not using just . It just goes to a blank screen saying no signal . But as soon as you turn off menus it switches straight back to the x box weird
DodgeTheViper
If my memory serves me right, there was a menu setting in the older Denon's to determine how the menu listing is displayed. So via HDMI or composite etc.
martin 39
Thanks for the help but there is no hdmI on the amp just s component pass through . Which is what I am using . I used this amp for yrs . But now can't seem to see menus . I think you might be right though about setting up menus been looking through the manual but can't seem to fine anything about it
DodgeTheViper
Does the remote have a receiver or amp button and have u pressed it ?
martin 39
Yes even on the screen off the remote it says set up when pressed . Or on screen display when I press that with remote set to amp . It just won't come up on the tv or front panel off the amp
Moviebuff
That's strange. It would certainly be a prerequisite that it is displayed on the front of the amp, if it is expected to be displayed on the TV screen as well.
Denons always show their setup parameters on the front display as well as the OSD. Have you tried pressing the setup button on the amp, as opposed to using the remote?
martin 39
thanks movie buff yea just seems so wired . I get the speaker volume levels on the front display but can get no set up . really frustrating as its for the boys room . . when I press set up it switches from Xbox to a blank screen then just shows the LG sign . I used this amp from new when they were launched yrs ago and had no problems on my old Panasonic plasma. have even tried 're setting the amp back to factory settings . and have tried composite to no avail . pulling me hair out now lol
Similar threads
