On Screen Display for Yamaha RX-V1200
Discussion in 'AV Receivers & Amplifiers' started by trbradley, Jul 16, 2002.
Tags:
  1. trbradley
    trbradley
    Help!
    For one reason or another, the on-screen display doesn’t seem to work when I’m running through the component outputs on my RX-V1200, however it works OK running through the standard rca video out (haven’t tried S-Video – No connection on my TV).
    Has anyone else had the same problem, and if so, did you manage to fix it, and how?
    Thanks all
  2. Electric Mayhem
    Electric Mayhem
    Mar 16, 2001
    10,629
    United Kingdom
    +2,233
    Are you sure it can actually output the OSD via the component outs? Most amps/receivers can´t. You usually have to use S-Video or Composite.
