On quad LNB which value 1,2,3,4,5
Discussion in 'Satellite TV, Sky TV & FreeSat' started by vectrasri99, Jan 16, 2005.
  1. vectrasri99
    vectrasri99
    When you install the quad LNB what value should you select 1,2,3,4 or 5.
    I selected the same as the old LNB (2 or 3 can't remember) but was just wondering.
    M
  2. bignairy
    bignairy
    Mar 13, 2004
    96
    Do you mean the alignment setting? If so then the same as your old one. Unless you have moved of course!
  3. neiljones
    neiljones
    May 29, 2002
    469
    northwest
    +13
    Whar part of the country do you live ?
    I live in Cheshire - my suggested alignment on the instructions that came with the LNB was number 3
    Check with manufacturer of LNB - easy enough to do that.
    NJ :lesson:
  4. vectrasri99
    vectrasri99
    SouthEast but the pic is fine and selected the same as the one that I took off.
    Cheers guys
    M
  5. DRGL
    DRGL
    Mar 30, 2004
    752
    Shropshire,UK
    LNB skew,usually 1,2 or 3 depending on location.
