On-line retail aftersales - advice reqd
Discussion in 'Plasma TVs' started by OBI-1, Apr 4, 2003.
  1. OBI-1
    OBI-1
    Guys,
    I am seriously considering the Pioneer PDP433HDE, which is retailing at around £4500 - £4700 in the shops. After a little research I have seen this item at around the £4k mark on some websites and obviously I am tempted to save my self a few quid and choose the online retailers over the high street.
    I am however concerned that should the unit develop a fault I will have all sorts of problems getting a replacement / loaner from any online retailer. Do you think my fears are unfounded, and if so, are there are online companies you can recommend for this product?
    I want to make sure that I get a proper u.k spec plasma with the manufacturers warranty etc.....!!!
    Any thoughts? :clown:
  2. TheBigApple
    TheBigApple
    Dec 10, 2002
    664
    In my cage
    +13
