On-Digital Phillips DTX 6371 !!!!
Discussion in 'Satellite TV, Sky TV & FreeSat' started by sezzi, Jan 9, 2003.
  1. sezzi
    sezzi
    I have one of these boxes and was wondering if it was or any use to me or i were able to view any chanels or should i leave it under my bed !!!!
  2. Fernsehman
    Fernsehman
    All ONdigital boxes still work with Freeview. There was some talk of some older boxes being incompatible with the new transmission standard but I've heard no recent evidence of this so it should be fine. The Nokia Mediamaster 9580, for example, is still just as good (and slow) as it ever was.
    Just plug it in and go through the "Store Channels" process. You may need to do the software update first. Not quite sure about this. I think it's mentioned here on this site.
    Fman
  3. sezzi
    sezzi
    ill get it out and try it will let you know
  4. Flimber
    Flimber
    Sep 22, 2002
    13,672
    Yorkshire
    +4,476
    Currently using one here for freeview. Shall I wait until you post for help with the parental lock code or shall I tell you to take the card out first before you do 'add channels' ?
    Mike.
  5. sezzi
    sezzi
    so i set up without the old subscription card in place then what im intruiged ?
  6. sezzi
    sezzi
    ive pulled the box out and am dusting off
    it looks ok still mind you i never used the thing in the 1st place
    the chanels were poor and limited
    ive removed the smart card !
    what next ?
    is there a proceedure ?
  7. Flimber
    Flimber
    Sep 22, 2002
    13,672
    Yorkshire
    +4,476
    Just take the card out, add channels and you're done. Although there was a critical firmware update for BBC channels at some point in the past I dunno if it affected these boxes.
    Mike.
  8. sezzi
    sezzi
    ok doing now
  9. sezzi
    sezzi
    humm how many chanels should i be expecting ?
    at present i have only 4
  10. sezzi
    sezzi
    still only four
    Uk History
    sky sports news
    Sky News
    & travel
    does it get any better that this ?
    mind you excellent reception !
    Alan
  11. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Should get 25-30 channels INC radio (12), maybe an upgrade to aerial needed. In Cardiff i get 30 in wolverhampton 24 some are repeat channels.
  12. sezzi
    sezzi
    humm ive tried to do update but get an error message
    so ive been looking for threads on here for 30 min
    with no real joy im just wondering if its worth resetting the whole thing "Does anyone know how to set the thing back to its shipping state"
  13. MonkeyDonkey
    MonkeyDonkey
    May 9, 2002
    401
    UK
    You need to choose Store Channels, not just add channels.
    This will remove all remains of ITV Digital channels and add the new Freeview lot.
  14. sezzi
    sezzi
    just done store channels and got 11-12-42 & 43
    no different i must be missing something ?
  15. nunew33
    nunew33
    Jun 5, 2002
    1,736
    41
    Lytham St Annes, where people are put out to grass
    Ive got all the channels on 25% signal strength using this box in an area where we arent supposed to have all the channels. I dont think my aerial is anything special so the box itself must be pretty good to provide that level of reception.
    Have you tried taking it to someone elses house who has a better arial or someone far enough away to make a comparison?
    The only problem I get is it crashes whenever I leave it on for more than a couple of days and needs to be switched off and on.
  16. MonkeyDonkey
    MonkeyDonkey
    May 9, 2002
    401
    UK
    What sort of reception did you get with ITV Digital?
    By the looks of it your just picking up Multiplex C.
    Stick your postcode in this http://www.dtg.org.uk/retailer/coverage.html
    Then click on the Link to info for retailers and installers about transmitters and aerials in the bottom right hand blue box.
    See if all Mux's are transmitted by the same transmitter.
