On a budget
Discussion in 'PC Gaming & Rigs' started by LickMyLemonss, Mar 1, 2013.
  1. LickMyLemonss
    LickMyLemonss
    Mar 1, 2013
    Hi there guys
    Basicly my laptops just broke and iam looking for a new pc
    now i want a that will play medium- high games
    i want a realtivle fast pc
    Now the only problem is i only have £260 and need a moniter aswell!
    I obviously wont be able to buy new but i dont mind that
    in my eyes i really have two options
    1. spend ages on ebay looking looking for a cheap used rig
    2. pay someone to build me one (or pay a computing local shop)
    I really dont know what to do because iam on such a small budget
    Any suggestions?
  2. LickMyLemonss
    LickMyLemonss
    Mar 1, 2013
  3. chrissav
    chrissav
    Dec 29, 2006
    156
    +13
    At that budget you are really tight to get anything semi decent, even used. One thing worth considering is selling your dead laptop on fleabay as it's surprising how much they go for even when dead.
    Chris
  4. LickMyLemonss
    LickMyLemonss
    Mar 1, 2013
    Hi guys once again wandering weather i could play games (like DayZ on Medium for example) on a rig as follows:
    Intel Pentium Dual Core E5800 @ 3.2GHz processor
    4Gb DDR3 Memory
    1Tb Hard Drive
    DVD-Super Multi Drive
    Intel GMA X4500 Graphics Card (on board)
    Multi-in-1 Media Card Reader
    8x USB ports
    ACPI c64-based PC (64 bit processor)
    Western Digital WDC WD10EACS-00D6B0 1 TB Sata Hard Drive
    ATI Radeon HD5450 Graphics Card with HDMI output, DVI output, RGB output
    HL-DT-ST DVDRAM GH60N DVD Super Multi Drive
    Standard PS2 Wired Keyboard
    Microsoft PS2 Optical Mouse
    Intel 82567V-2 Gigabit Network Adapter
    Intel ICH8R/ICH9R/ICH10R/DO SATA Raid Controller (on board)
    Removable SATA Hard Drive Caddy
    Windows 8 Professional (freshly installed ready to run)
    any help is greaty thanked haha
  5. bladedripper
    bladedripper
    Nov 26, 2007
    5,071
    Birmingham
    +1,527
    First things first i don't want to lick your lemons..:devil:
    That pc you have listed is rubbish mate for games,you need about £400 before you start looking for a gaming rig..:smashin:
  6. Four quid mate
    Four quid mate
    Jul 26, 2012
    914
    46
    Hereford, UK
    +147
    Sorry mate, £260 won't even cut it for a rig that'll run games on medium settings. You're going to have to up your budget by a fair bit, the GPU alone will use half that budget if not more.
  7. TheNameIsJambo
    TheNameIsJambo
    Feb 4, 2011
    6,141
    Fife
    +1,696
    You need £500-ish to build a rig matey.
    Get that hepussy out on the street corners and start earnin'! :smashin:
  8. Sinzer
    Sinzer
    May 25, 2002
    5,829
    +1,120
    If you check Jambos signature, you will be lucky to find one component that costs under 500 quid!!
    A budget of 260 would get you a HDMI cable maybe :p
  9. Cha1ky
    Cha1ky
    Nov 26, 2007
    50,093
    The Internet
    +25,109
    Obviously a monster cable that's got gold plating on the connections to give you a better picture....
  10. TheNameIsJambo
    TheNameIsJambo
    Feb 4, 2011
    6,141
    Fife
    +1,696
    It even gives you 30 fps extra!
  11. GMC79
    GMC79
    Apr 1, 2006
    10,641
    Glasgow
    +3,177
    If he was ok at building (said he not tho) then could build ok for £300 if all 2nd hand (christ minus monitor, sound and ssd's could mayb build mine for that all 2nd hand nowadys). Not always easy finding all parts that way and if need monitor too then it's too low a budget.
    You be better of just saving a little for the £500ish and getting better when you can.:) Be worth it it the end, please dont go buying anything with a 5450 :nono: And avoid ebay prebuilt dodgy looking adds.
  12. LickMyLemonss
    LickMyLemonss
    Mar 1, 2013
    Thanks for all the replys!:)
    ive had a looks around for some cheap used pc parts
    CPU-Ram-Motherboard in Morecambe, Lancashire | Memory, Motherboards & Processors for Sale | Gumtree.com
    ASUS GTX 460 DIRECT CU TOP GRAPHICS CARD for sale in Worcestershire | Memory, Motherboards & Processors for Sale | Gumtree.com
    and found these
    now iam quite stupid and dont know much about building pc's but i know
    someone who does ( a friend) i was wandering if a baught these parts
    took them to someone or a shop could they just put them in a case and buy all the other stuff needed then have a decent pc?
    thanks and sorry iam soo dim haha:D
  13. TheNameIsJambo
    TheNameIsJambo
    Feb 4, 2011
    6,141
    Fife
    +1,696
    :laugh:
  14. LickMyLemonss
    LickMyLemonss
    Mar 1, 2013
    bump for last question:)
  15. Dave2
    Dave2
    Sep 9, 2006
    3,965
    Newcastle Upon Tyne
    +529
    a shop will charge you, best if you know someone that will do it for a pint
  16. Dave2
    Dave2
    Sep 9, 2006
    3,965
    Newcastle Upon Tyne
    +529
    remember there is no point getting a good graphics withough good cpu or memory because the cpu will bottleneck your gpu.
    For £260 you will struggle, the cheapest machine i done for someone was around £380 to £400 a few years back and that had a gt 9400 in it and a cheap amd x2 and it played batman arkham asylum real well .
    If you have money issues maybe a little credit with a nice 0% apr and stretch that budget to £500, you can pay half of it off instantly and you have 12 months to save up. However i would suggest this if you can afford to do it.
    Also building your own computer is nice and alot easier to do than how it used to be as nowadays you just need to jump into bios and default settings will boot your computer up and then a little web surf will help you get the best bios settings to suit you .
    Just remember when you do your own build you will need and OS if you aint got one as its not like just buying a computer and os is installed.
  17. LickMyLemonss
    LickMyLemonss
    Mar 1, 2013
  18. PocketBunny
    PocketBunny
    Oct 5, 2010
    3,283
    +680
    im going to be blunt.
    Wait until you have more money before you buy anything. For what you want to do, you need twice as much cash.
  19. TheNameIsJambo
    TheNameIsJambo
    Feb 4, 2011
    6,141
    Fife
    +1,696
    +1.
  20. Sniper Ash6
    Sniper Ash6
    Jun 5, 2008
    27,850
    127.0.0.1
    +7,663
  21. TheNameIsJambo
    TheNameIsJambo
    Feb 4, 2011
    6,141
    Fife
    +1,696
    :rotfl: Jesus ****ing Christ mate. I had a computer like that back in the early 2000s (if not earlier). Are you actually kidding us here?
    You WILL NOT get a computer that can play any modern games for £200. Do not throw your money away.
    Spend at least 3x that much, and yeah, you'll have a cracking computer.
    My recommendation to you, if you're so desperate to get a new computer, goto a casino with your £200, bet on black, and see what happens.
    On one hand, you could double your money, you could build a basic £400 computer and on the other, you'll be left with nothing - Which is exactly what you would be if you bought that damn thing.
    EDIT:
    My Galaxy SIII has more computing power than that rig.
  22. Four quid mate
    Four quid mate
    Jul 26, 2012
    914
    46
    Hereford, UK
    +147
    "Spent a good £700-800" maybe when Windows 95 was new.
  23. jackw123
    jackw123
    Aug 22, 2011
    172
    +21
    Lol wouldnt bother with any off that scrap you listed man wate of money i agree with the others. Day z is a bastard to run well anyway so save up and get something thats not a fossil or an embarassment!
  24. TheNameIsJambo
    TheNameIsJambo
    Feb 4, 2011
    6,141
    Fife
    +1,696
    Maybe he's from a developing region where that technology is brand new...
    Oh wait.. Leeds..
    I see.. :D
  25. Four quid mate
    Four quid mate
    Jul 26, 2012
    914
    46
    Hereford, UK
    +147
    :rotfl::rotfl::rotfl:
  26. jassco
    jassco
    Feb 10, 2009
    6,090
    +3,096
    Its quite generous suggesting it is even developing :D
  27. Foster
    Foster
    Sep 25, 2011
    15,978
    2
    West Yorks
    +7,174
    What does that mean jambo :O bastard xD.
  28. nero0410
    nero0410
    Jan 5, 2004
    12,667
    Weston Super Mare, UK
    +5,006
    :rotfl:
    If he really paid that they saw him coming. What a prat.
    A mobile phone has more power these days.
    It is really worth saving the cash, spending out on something with less power will only lead to disappointment when it fails to play even solitaire.
    tris
  29. Houghsx
    Houghsx
    Mar 20, 2006
    9,131
    City 17
    +3,365
    For that budget you would get better results with one of the consoles. Listen to everything people have been saying, seriously.
  30. Razor
    Razor
    Dec 15, 2004
    37,726
    2
    +12,503
    Agreed.
